Solved by Alfred.NESWADBA. Go to Solution.
what product & version & servicepack did you use when you exported your profile, what product & version & servicepack did you use to import that profile?
- alfred -
>> everything goes back to defaults
So to reproduce I tried: added a path to the support paths, applied the changes, exported the profile, closed AutoCAD, opened AutoCAD, imported this ARG-file to a new profile-name, made this new profilename active ... and now you lost the added support-path? Sorry, I can't reproduce that, for me that woked.
To get more close to the problem we have to start at:
a) is the export defect
b) is the import defect
...therefor open the ARG-file in an editor (notepad++ or similar) and see if the changes, in the above sample the path added, are present in the ARG. So we know where to search, a) or b)
- alfred -
can you upload the ARG file here? Maybe it's necessary to ZIP it.
And just to make sure: you are sure you gave the imported profile a new name ... and that new name is then listed in the list of profiles.
And a second check: are you sure you have enough permissions to rewrite the registry (as the import needs)?
- alfred -
>> Here's the file
Not here. Have you zipped it?
>> I'm an admin on my pc so i would hope that i could write permissions
Not necessarily, try to start AutoCAD via right-click and option "Start as administrator", then you have your full permissions.
And please let me know what detail you modified so I can look to that after importing it.
- alfred -
