I downloaded AutoCAD architecture 2014 on my windows 7 home premium, but when I click on the application it says "the application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail." I tried repairing it but that doesn't work. Please help!
>>>crosspost<<< does not help you and does not help others.
And even if you tried AutoCAD and AutoCAD Architecture, the source of the problem is the same.
