AutoCAD Forum
A little help please?
2 REPLIES 2
JessicaRamos430
565 Views, 2 Replies
I downloaded AutoCAD architecture 2014 on my windows 7 home premium, but when I click on the application it says "the application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail." I tried repairing it but that doesn't work. Please help!
2 REPLIES 2
>>>crosspost<<< does not help you and does not help others.
And even if you tried AutoCAD and AutoCAD Architecture, the source of the problem is the same.
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
pendean
in reply to: JessicaRamos430
The second part of your posted error message instructs you on what to do to find out more about the problem. Do so now and report your findings if you can't figure it out.
”Boost
