Is there an easy way generate an index of details (sheet views) with the same ease as generating a sheet index from the Sheet Set Manager? Right now I'm just plugging in the fields in each cell, but thought I should ask if there is an easier way. Autodesk if you're reading this, can you build in this feature with the next release?
Thanks!
Hi Juliet,
I think your method of using fields to enter the views into a table as Objects or Named Objects may be the best option. You might also be able to do something with a callout block to pull attributes if you wanted more data in the table. I did also search https://apps.exchange.autodesk.com/ to see if anyone had created an app for this, but did not find anything.
But, you do raise a good case for adding this enhancement to the product. If you would take the time to go here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
This is a feedback page where customers can make suggestions. This page is monitored by product managers who affect real change and this request can go a long way in changing the product for the better.
