AutoCAD Forum
3d face object no extrude !
9 REPLIES 9
Message 1 of 10
grfkpc
1382 Views, 9 Replies
hi;
3d face extrude objects around 4,500 triangles made. While most of them extrude, extrude objects up to 650 yet. I've tried many methods, but this 3D face objects How can I extrude. My goal as a solid curved surface of a mountain and then turn solid model all combine to make straight the following section.
The following are sample files.
above sloping to flat surfaces extending below 3dFace solid objects you want to do.
Greetings.
9 REPLIES 9
Message 2 of 10
in reply to: grfkpc
HI,
 IN MY OPINION, YOU BETTER MAKE IT IN MESH,,, WHEN U ARE DONE CREATE A SOLID THEN SLICE IT USING THE MESH IN SLICE USING SURFACE OPTION.
GOOD LUCK,
VIRGILIO BENEDICTOS
Message 3 of 10
Alfred.NESWADBA
in reply to: grfkpc
use _EXTRUDE with option PATH (using a vertical line created before) or using option DIRECTION.
(file attached)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 10
grfkpc
in reply to: Alfred.NESWADBA
I opened the file that you have sent, but apparently the upper triangular spaces should not be. my problem is I already Occasionally Occasionally while extrude the triangles can not be extruded.
Thank you.
Message 5 of 10
grfkpc
if convert to mesh I'm having a problem with this...
attach picture.. and attach original document.
help me ..
thanks.
Message 6 of 10
Alfred.NESWADBA
in reply to: grfkpc
ok, have not seen that there were small gaps, sorry.
For that type of objects you can use command _REGION to convert the 3DFace-objects to Region objects. These objects can then be extruded.
- alfred -
Alfred NESWADBA
Message 7 of 10
grfkpc
in reply to: grfkpc
if convert to mesh this message " Hatch boundary associativity removed "
Message 8 of 10
grfkpc
I tried the region. but it was all mesh objects. I am getting the following error when I do extrude. can not sweep or extrude an object of this type. 6383 removed the object from the selection set.
Message 9 of 10
Alfred.NESWADBA
in reply to: grfkpc
I meant you should use _REGION command to convert your 3D-faces, not any mesh objects (at least within your drawing I don't find any mesh-objects at all).
- alfred -
Alfred NESWADBA
Message 10 of 10
hello...
you can also use 3D POLY command (3P) in to create 3D face then like alfred said create vertical line use for path option in extrusion,,
hoping this will solve your problem.
regards
Virgilio Benedictos
PS
pls give me kudos if problem solve
”Boost
