Hi all!
How can I save the visual settings in cad2014?
I change the visualization resolution (to see more isolines, better surfaces,...) and apply it, I save the profile, but when I close cad and open it again with the same profile the settings are the original ones
thanks!
Solved by GrantsPirate. Go to Solution.
Solved by steve216586. Go to Solution.
Are you refering to the settings in OPTIONS under the Display and 3D Modeling tabs for visual settings? If so, they are stored in the drawing and not in the user profile.
If you open a drawing and make your changes and then save that drawing, the next time you open that particular drawing, the settings should show the changes. However, if you are opening a template drawing or selecting NEW, and making your changes, but not saving it, when selecting the template again or selecting NEW, your changes will not be in effect.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
