I have a vertical construction which isn't orthogonal, I drawed 3 layers to use the Loft-tool via cross sections, and it works, but not ruled but kind of smooth. But I definitely need it ruled.
I somehow couldn't attach the dwg-file, so I attached a screenshot. There you can see, that the upper solid doesn't end at the same point as the lower solid (U-form). Maybe someone knows a solution (and also about why I can't attach a dwg-file) 😃
thanks
Let's start here, because if we have the sections we can try it with your DWG-file.
So what message did you get when you tried to attach the drawing? And if you create a ZIP-file do you get the same message?
One reason might be the filesize as this is limited to 1.5MB in this forum.
BTW: the objects look like surfaces and not like 3D-solids.
- alfred -
