AutoCAD Forum
3d Grips missing
5 REPLIES 5
peri
400 Views, 5 Replies
3d Grips missing
Hi -
I have a persistent problem with 3D grips missing (or at least invisible and not functioning).  Both my co-worker and I are not power ususers, but we do use AutoCAD Architecture 2010 every day, all day designing homes for our clients.
We took a free trial of AutoCAD 2014 to see if it is worth upgrading, and when I import our DWGs, everything is fine except our 3D walls do not have grips.  The flattened lines work fine.
Can anyone think of a solution or reason?  I wouldn't want every floor plan we've ever worked on to be non functional if we upgrade to 2014.
5 REPLIES 5
peri
in reply to: peri
Note that this problem only occurs when I am not on the network & working in my office. If I am working from home (or elsewhere) the 3D grips disappear.
Patchy
in reply to: peri
You took a free trial of AutoCAD 2014 instead of "2014 Arch", maybe that's why.
peri
in reply to: Patchy
No, it turns out the same thing is happening on ACA 2010 on my laptop.
Patchy
in reply to: peri
If you ask the Arch group, they probably know.
http://forums.autodesk.com/t5/AutoCAD-Architecture/ct-p/56
JoAnn_Hogan
in reply to: peri
How do you import your drawing? Which steps are you following?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
”Boost
