AutoCAD 2013/2014/2015
Active Member
Message 1 of 9 (339 Views)
Accepted Solution
3D trim newbie! help!
339 Views, 8 Replies
10-05-2012 08:41 AM
Hi! i'm a Autocad 3D newbie! Have some problems to figure out how to trim a solid from a sphere. well here's an image that will explain better!( it's the pink part from the green)
thank you so much !
*Expert Elite*
Patchy
Message 2 of 9 (334 Views)
Re: 3D trim newbie! help!
10-05-2012 08:44 AM in reply to: nicole.ravasini421
Trim doesn't work, use SUBTRACT
Active Member
Message 3 of 9 (332 Views)
10-05-2012 08:45 AM in reply to: Patchy
the subtract command subtracts the whole pink solid and leaves the empty shape in the sphere, I just need to cut the part that sticks out from the bottom of the sphere!
*Expert Elite*
Patchy
Message 4 of 9 (323 Views)
10-05-2012 08:52 AM in reply to: nicole.ravasini421
Attach your drawing here.
Active Member
Message 5 of 9 (321 Views)
10-05-2012 08:55 AM in reply to: Patchy
*Expert Elite*
Patchy
Message 6 of 9 (307 Views)
10-05-2012 09:56 AM in reply to: nicole.ravasini421
Subtract command.
Active Member
Message 7 of 9 (302 Views)
10-05-2012 10:05 AM in reply to: Patchy
thanks!!
but how did u do it? subtract and?
*Expert Elite*
Patchy
Message 8 of 9 (299 Views)
10-05-2012 10:15 AM in reply to: nicole.ravasini421
Thanks for the challenge, it was not as EZ as I thought.
I had to make a copy of the model, SUBTRACT the unwanted parts, then SEPARATE them, after that I move them back to the original position.
Active Member
Message 9 of 9 (283 Views)
10-05-2012 12:03 PM in reply to: Patchy
Thank you!!! gonna try to repeat it myself, gotta learn!!!!
thanks again!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
