AutoCAD Forum
2015 - Layer Properties Manager losing selection...
27 REPLIES 27
Message 1 of 28
darawork
2589 Views, 27 Replies
Hi all,
Upon selecting several layers in the Layer Properties Manager, then trying to say... freeze the selected layers, THEN turn the selected layers off, the Layer Properties Manager will lose the previous selection before you can do the second icon press. This necessitates the user to having to select the entire layer selection all over again. It was not like this in previous versions.
Can someone with AutoCad 2015 check to see if this is the case with their installation?
Thanks guys.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
27 REPLIES 27
Message 21 of 28
robyn.henke
in reply to: nrz13
Unfortunately, I do not have that information in a handy Excel file like I do what software is installed on everyone's machines.
I do know that more often then not, not one laptop or desktop has the same configuration, which means 15 different graphics cards!
I am not in charge of ordering new machines, that lies with one of the owners who likes things quick and often times, cheap, so he gets what is available.
Horrible practice, I know, believe me, I know!
Anyway, I hate to be chalking all of these glitches up to graphic card issues.  With all the new features and more then likely new system settings, I want to assume it is some sort of setting first.
Message 22 of 28
JeffPaulsen
in reply to: robyn.henke
Don't know if this will be any help or not but in C3D 2012 I see this behavior only when LAYERDLGMODE=1 & using the Unreconciled Layers filter. I have not seen this behavior any other time.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
Message 23 of 28
robyn.henke
in reply to: JeffPaulsen
I was just going to post this!  I had my laptop user set her layerdlgmode to 1 and it solved her problem.  We had made the change to 0 with 2014 because the layer list was not only showing layers in an xref when that was selected, we saw all the layers, all the time.
This may be the solution then?
Message 24 of 28
in reply to: darawork
Same thing happens in 2015LT. I'm here looking for a solution.
Anne
Message 25 of 28
darawork
Changed layerdlgmode to 0, problem still exists.
Darawork
AutoDesk User
Message 26 of 28
CadMonkeyJon
Has anyone got to the bottom of this yet or is it a bug that Autodesk have not fixed yet?  I have the same issue, regardless of layer filters, exactly as per Nestly2's video.
I have changed my LAYERDLGMODE to 0 and it mostly seems to have fixed it but not always.
Message 27 of 28
nrz13
in reply to: CadMonkeyJon
AutoCAD 2015 Service Pack 2 fixed the problem for me.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 28 of 28
nestly2
in reply to: nrz13
Also fixed here with AutoCAD2015 SP2
”Boost
