i try to instal autocad 2014 service pack 1 for 32 bit windows 7 network and it says cannot install product not found. i notice the autodesk webpage shows it applies to autodesk product design suite but not autodesk product design suite premium.
will there be different autocad service packs depending on the package it was installed from?
Solved by DarrenP. Go to Solution.
you need to install the mechanical 2014 or the electrical 2014 service pack
product design suite doesn't come with a separate installation of autocad 2014
the autocad installation is coming from the mechanical or electrical installation
which is a different directory from just a regular autocad installation
DarrenP
AutoCAD 2014 in the Product Design Suite 2014:http://upandready.typepad.com/up_and_ready/2013/07/where-is-autocad-2014-in-the-product-design-suite...
DarrenP
thank you.
do you know why autocad installs have errors writing to c:\config.msi? i just had one, hit retry, no problem after that.
