AutoCAD Forum
2014 Adjusting Aperture Size
4 REPLIES 4
16240 Views, 4 Replies
Just wondering if anyone can confirm this bug or if it is in fact a bug?
The aperture size cannot be modified using the sider under options. Workaround seems to be to use the system variable “pickbox”. Occasionally it seems to also display as a rectangle instead of a square, obvious when variable is set below 10 (however, this seems to be one of those intermittent problems / might be a stand-alone graphics problem).
I've got SP1 installed.
4 REPLIES 4
nestly2
Aperture and pickbox are often confused.  The Aperture is only active when AutoCAD is expecting the user to pick a point, and only when OSNAP is enabled.  By default, the Aperture is not displayed, therefore moving the slider would have no visual affect.
The Aperture slider is on the Options > Drafting tab, whereas Pickbox slider is on the Options > Selection tab.
To test, turn the Aperture display on (APBOX = 1) then with OSMODE something other than 0 enter a command that expects the user to specify a point, ie LINE command.
As for the Square vs Rectangular Aperture/Pickbox, I beleive you are correct that it's related to the graphics configuration.
pendean
If you are running your monitor at it's designed optimum display, not something else through Windows Display settings, the 'rectangle' will become a 'square' again. This is a user-created issue.
stevev0983
Try changing the number of lines on your command line. If you have 2, change it to 3, etc.. This is a very annoying problem that has been around for years and this is the only thing I found that actually fixed it.
Mine already is and doesn't seem to explain the intermittent nature of the problem.
Thanks. Strange workaround but it did work for me!
Perfect! Can't believe I mixed that up. I only make these changes once per upgrade so I've totally confused myself. Thanks for your help.
”Boost
