• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2012
    Valued Mentor
    JamaL9722060
    The “intersection osnap” between a “hatched rectangle” and a “DASHDOT2”
    47 Views, 2 Replies
    02-22-2012 03:23 PM
    The AutoCAD doesn’t show the “intersect osnap” at certain zoom!
    I’m not sure about this behavior
    The “intersection osnap” between a “hatched rectangle” and a “DASHDOT2” line appears and disappears depending on the amount of zoom!
    As I zoom out the “intersection osnap” appears but when I zoom in, it disappears
    Is there any explanation for this behavior?
    Why the "intersection Osnap" should disappear as I zoom in?
    Thank you
    Regards
    Jamal
    Jamal NUMAN, GIS Analyst, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank
    Software: AutoCAD 2012, Windows 7 Ultimate X86, FireFox 9.0
    *Pro
    nestly
    Re: The “intersection osnap” between a “hatched rectangle” and a “DASHDOT2”
    02-22-2012 04:57 PM in reply to: JamaL9722060
    If the displayed portion of both dashed lines are not both within the aperture, then the running Intersect Osnap will not find the intersection.    That's just the way it is.  You can zoom out, regenerate the drawing and perhaps the lines will cross where they're both displayed, or you can manually specify the Intersect Osnap (or the Apparent Intersect OSnap) and then pick each line separately.  I typically use the last option, using Shift+Right Click to access the OSnap menu
    What's an Aperture?
    Valued Mentor
    JamaL9722060
    02-23-2012 02:29 PM in reply to: nestly
    Thank you for the answer Nestly. this is quite helpful.
    best
    Jamal
