AutoCAD 2012
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Selection order
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi all,
Apologies for the brain fade...
What is the variable that controls the order in which objects are selected? In other words, I want to be able to always select the last object created by default when objects are overlapping without using object cycling...
John
Re: Selection order
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not sure about a variable or a default setting, but what about using a Select option. When prompted to Select Objects enter L for Last to select the last item, or use other selection options as needed. See following Select documentation:
SELECT
C3D 2012 SP1, Win XP Home
Re: Selection order
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your reply.
That's not really what I'm after.
Until a day ago, if I drew say two overlapping lines. Clicking on the lines would automatically highlight (select) the last one drawn. This is very handy as most often you are working with the last object created. I'm sure there is a variable that controls this behaviour, but I just can't find it at the moment.
Using command line prompts does not work since the object you are after is not always the last, or previous ... object created. Cycling through these objects is the only way to isolate which one you want, but this can be tedious if you have to do it all the time...
John
Re: Selection order
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So are we maybe talking about the SELECTIONCYCLING variable set to 1?
Re: Selection order
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Found it ![]()
Sortents...
Bitcode 1 has to be included.
John
Re: Selection order
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ah, new one on me. Glad you figured it out. ![]()
