• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2012
    Dimension overrides using match properties
    60 Views, 2 Replies
    02-22-2012 09:32 AM
    In 2011 AutoCAD Mechanical, I used to be able to match dimension override properties including the entered text.  Not sure how it worked, but the manual entered text would be matched/transferred to the new default dimension.  Now using 2012 and this function is not working.  This feature is quite handy for the type of work we do. All match property settings are enabled.   Any help is appreciated.
    Distinguished Mentor
    Bob_Zurunkle
    Re: Dimension overrides using match properties
    02-22-2012 09:36 AM in reply to: mcaru
    Umm this is the NillaCAD forum, not Mechanical. Are you using just the NillaCAD version? Because it isn't a NillaCAD feature. Otherwise, if memory serves, try your AMPOWERDIM settings...
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
    *Pro
    nestly
    02-22-2012 09:37 AM in reply to: mcaru
    I know they did make some changes to MATCHPROP between 2011 and 2012, however I'm actually surprised it worked like that for you.
    Did you know you can change the settings for MATCHPROP?  Start the command, pick the source, then look at the command line  (type S, for Settings)
    Good luck.
