• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2012
    Active Member
    resullins
    Array Function
    861 Views, 18 Replies
    03-24-2011 08:05 AM
    The array command in 2012 acts oddly. It works in the command line now, instead of a dialog box. Which I guess is handy. But when it arrays, it makes everything you've arrayed one object, and you have to explode it if you're going to manipulate them individually.
    Does anyone know if there's a way to convert that back to the legacy way of doing things?
    Distinguished Mentor
    rkmcswain
    Re: Array Function
    03-24-2011 08:13 AM in reply to: resullins
    What you describe is how it now works in 2012.
    Unfortunately, there is no CLASSICARRAY command.
    ****Sage
    Re: Array Function
    03-24-2011 08:25 AM in reply to: rkmcswain
    -ARRAY (note the dash) is the 'classic' method (yeah, no pop-up).
    Please mark any response as "Accept as Solution" if it answers your question.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    RSS: http://ltisacad.blogspot.com/feeds/posts/default
    Twitter: http://twitter.com/LTisACAD
    Pinterest: http://pinterest.com/pendeaninc/pins/
    rkmcswain
    Re: Array Function
    03-24-2011 08:30 AM in reply to: rkmcswain
    But it looks like it may be available soon...
    http://www.blog.cadnauseam.com/2011/03/22/autocad-2012-array-has-good-and-bad-points/
    Actually, that it the same command line version of Array that was in 2011, 2010, etc.
    I expect "ClassicArray" to work in the same way as the previous release.
    Active Member
    resullins
    Re: Array Function
    Crap... where's the wishlist for 2012? I really miss my pop-up.
    *Pro
    Re: Array Function
    03-24-2011 08:32 AM in reply to: resullins
    During the array command, you will have the option to set ASsociativity. Setting that to No will create separate objects like the old array command did.
    Tim Corey
    Tim Corey
    Delta Engineering Systems
    Redding, CA
    rkmcswain
    Re: Array Function
    03-24-2011 08:34 AM in reply to: tcorey
    Tim Corey
    Thanks. I glossed right over that option. :smileywink:
    rkmcswain
    Re: Array Function
    03-24-2011 08:37 AM in reply to: resullins
    Actually, it would be for 2013 (Hmmmm.. I wonder if they are really going to name it "13"...)
    Anyway, the Augi Wishlist is under construction, but you can also submit product feedback here.
    Re: Array Function
    03-24-2011 11:58 AM in reply to: resullins
    To manipulate hold control down, select, (select others) pick the red grip. Also, have the Ribbon on to see the editing options when you pick on the array. Finally, pick the array, hold the cursor on the grips to see other options.
    Active Member
    resullins
    Re: Array Function
    03-24-2011 12:23 PM in reply to: COJonez
    Yeah, but I don't just need to physically manipulate them. I usually array text lines for a TCOUNT command. Or blocks and then sequentially number them. I have to explode whatever it makes.
    I think mostly I don't like the fact that it doesn't remember your previous inputs.
