• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2011
    Member
    eirinigrigo
    moving tool problem
    123 Views, 11 Replies
    01-28-2012 08:50 AM
    when trying to select one line to move it moves any line touching the selected line even when they aren't selected.
    This is driving me insane! Could you help me please?
    **Master
    Re: moving tool problem
    01-28-2012 08:58 AM in reply to: eirinigrigo
    does this line belong to a group? Or is this line just a segment of the polyline or part of a block?
    To verify if it's a line or not start command _LIST, then select the object and let us know what is reported in the command area, especially the object-type
    If it's reported to be a line then it may be grouped with other objects. You can then try to change the sysvar PICKSTYLE to 0 (>>>details<<<) and look what happens now when you try to move the line.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    **Master
    Patchy
    01-28-2012 09:03 AM in reply to: eirinigrigo
    They are constrained to one another, delete the constrained.
    **Master
    01-28-2012 09:06 AM in reply to: Patchy
    great idea, sorry that I forgot this possibility :smileywink:
    - alfred -
    Alfred NESWADBA
    **Master
    Patchy
    01-28-2012 09:15 AM in reply to: alfred.neswadba
    Only OP knows, we can only guess
    Member
    eirinigrigo
    01-28-2012 09:18 AM in reply to: alfred.neswadba
    Thank you very much.It reports that it is LWPOLYLINE.What do i have to do now?Do i have to change the sysvar PICKSTYLE to 0?How can i change it?
    Irene
    Member
    eirinigrigo
    01-28-2012 09:22 AM in reply to: Patchy
    OK :smileyhappy: thanks a lot.
    Could you please explain me how can i delete the constrained, because i am new user and i hae no idea?
    Irene
    **Master
    Patchy
    01-28-2012 09:25 AM in reply to: eirinigrigo
    Polyline, you use command EXPLODE
    In this case it's not constrained.
    **Master
    OK, a polyline (what type if polyline ever) is one object containing segments and these segments are connected together.
    If you don't want to lose this connections you can either use the grips or command _STRETCH (>>>details<<<) to move a segment and hold the connections.
    If you don't need this connections you can use thte command _EXPLODE (>>>details<<<), this converts the segments of the polyline to single objects, straight segments are converted to lines, others to arcs.
    - alfred -
    Alfred NESWADBA
    Member
    eirinigrigo
    01-28-2012 09:27 AM in reply to: Patchy
    That works :smileyhappy: thanks a lot again.
