• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010
    New Member
    alextheong
    converting to pdf
    192 Views, 1 Replies
    02-01-2012 09:52 PM
    when i try to convert my drawing to pdf, the pdf file comes out blank.
    also, i use autocad 2010. is it possible to open up my dwg in another computer with autocad 2007?
    **Master
    Re: converting to pdf
    02-02-2012 04:06 AM in reply to: alextheong
    How did you try to "convert" it? What tools or what AutoCAD commands did you try?
    I would create a layout and plot to the "DWG to PDF.pc3", then I set the papersize, create viewports, zoom and pan and set scale to get the correct view into the viewport(s) and ==> PLOT :smileywink:
    You can open the drawing with AutoCAD 2010, then do _SAVEAS and within the file-dialog you can set the format to DWG2007. Then you can open this file with AutoCAD 2007
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
