• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010
    Distinguished Contributor
    Very slow file
    195 Views, 6 Replies
    02-10-2012 02:33 AM
    A drawing is almost (20 MB). It is big I don't know why? It works normal in MODEL space. But when I switch to PAPER space, or to save, print, close and open the file, it shows very slow reaction.
    I made reset to the scale, cheking LTScale, deleted all un necessary objects, purge several times, UCS dynamic off, AUDIT, cheking Xref's, texts are type (shx), No layers filters.The drawing has only one layout en few viewports. (isavepercent) to 0.
    But all these things did not help.
    What can I do more to reduce the file size en make it faster?
    Thanks all.
    ****Sage
    Re: Very slow file
    02-10-2012 07:42 AM in reply to: jz4all
    Unless you have something unique drawn or referenced in the Lyaout (a raster image, or dense hatching or...), it's just your graphics card having a hard time handling the info there. No real fix.
    Which is it?
    Please mark any response as "Accept as Solution" if it answers your question.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    RSS: http://ltisacad.blogspot.com/feeds/posts/default
    Twitter: http://twitter.com/LTisACAD
    Pinterest: http://pinterest.com/pendeaninc/pins/
    Re: Very slow file
    02-14-2012 02:57 AM in reply to: jz4all
    Beside all what I mention above, I did all kinds of (purge, pu as well -pu). In modle the space it works normal but in the  paper space  it works very slow (regenerating, save , open the drawing when it is saved on paper space, awitching from model space to paper space...etc).
    Any advice?
    ****Sage
    Re: Very slow file
    02-14-2012 05:24 AM in reply to: jz4all
    What are your PC and video card specs? Windows version?
    Is each viewport set to anything other than SHADEMODE at 2D?
    Dean Saadallah
    Re: Very slow file
    02-14-2012 06:33 AM in reply to: jz4all
    Thanks for your reaction,
    Win 7 Enterprise
    Graphic NVIDIA
    all viewports on 2D
    Distinguished Mentor
    Bob_Zurunkle
    Re: Very slow file
    02-15-2012 09:12 AM in reply to: jz4all
    I am wondering if OP has it set to do a regen for example, on every one of the changes they noted this behavior on (behaviour in Canada; behaviour:30 in NFLD)
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
    Valued Mentor
    thepworth
    Re: Very slow file
    02-15-2012 10:09 PM in reply to: jz4all
    2 things to try -
    1) -purge "R" for regapps "*" for all - don't confirm....
    2) check the setting of layoutregenctl - see if changing to modify regeneration setting reduces caching and speeds things up.
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
