Matches don't appear in PDF...
We PDF drawings to send to clients.  Of course we have a concern for the resulting presentation quality.
An example of the problems we encounter occur with the elevation drawings.  Most of them contain hatches  & patterns that need to be displayed in the final drawing.  However, when we plot to a PDF drawing from within AutoCAD, many of those patterns will disappear in the PDF copy.
I am aware that if we plot a drawing to PDF the quality will be better.  However, my file size increases exponentially - starting with a 300+k DWG file - it suddenly balloons to a 1.0mb PDF file.  If I use the "Export - PDF" option - the resulting PDF file is smaller (within the same files size range as the original DWG).  But, I consistently lose many of my hatch patterns.
My question:
How do I maintain my hatch patterns when creating a PDF?
How do I reduce (optimize) my PDF files?
Thank you
Do you see your patterns on plot preview? - if not change the hatch scale.
to get smaller pdf size - you can use pdf creator instead of dwg to pdf plotter. you will lose all those fancyturn on/off layers things, but your file will be dramatically smaller - sometimes from 3-4 megs to 150-250 kbs.
you can also lower the printing resolution in custom options - that will also lower the size of pdf file.
And what works VERY well - you can first publish your file to DWF and THEN print it to PDF from DWF viewer.
heinsite
>>And what works VERY well - you can first publish your file to DWF and THEN print it to PDF from DWF viewer.<<
This is a trick I learned a long time ago that I still use.  Originally it would *dramatically* reduce the filesize of the resulting PDF.  It doesn't have much of an effect that way anymore, but there are often noticable quality improvements still.  Excellent reminder tip.
Dave.
Dave Hein, P.E.
Thank you for your input.
I am just now experimenting using your advise.  I like that the DWF files retains a lot of the image quality while keeping the file size small.  But unfortunately clients are familiar with PDF and request them in that format.
But I will definitely use this advise.
Thank you again!
I hope you didn't forget the second step - print to PDF from dwf file using autodesk design review ? 🙂
