AutoCAD 2010
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Matches don't appear in PDF...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We PDF drawings to send to clients. Of course we have a concern for the resulting presentation quality.
An example of the problems we encounter occur with the elevation drawings. Most of them contain hatches & patterns that need to be displayed in the final drawing. However, when we plot to a PDF drawing from within AutoCAD, many of those patterns will disappear in the PDF copy.
I am aware that if we plot a drawing to PDF the quality will be better. However, my file size increases exponentially - starting with a 300+k DWG file - it suddenly balloons to a 1.0mb PDF file. If I use the "Export - PDF" option - the resulting PDF file is smaller (within the same files size range as the original DWG). But, I consistently lose many of my hatch patterns.
My question:
How do I maintain my hatch patterns when creating a PDF?
How do I reduce (optimize) my PDF files?
Thank you
Re: Matches don't appear in PDF...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you see your patterns on plot preview? - if not change the hatch scale.
to get smaller pdf size - you can use pdf creator instead of dwg to pdf plotter. you will lose all those fancyturn on/off layers things, but your file will be dramatically smaller - sometimes from 3-4 megs to 150-250 kbs.
you can also lower the printing resolution in custom options - that will also lower the size of pdf file.
And what works VERY well - you can first publish your file to DWF and THEN print it to PDF from DWF viewer.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
>>And what works VERY well - you can first publish your file to DWF and THEN print it to PDF from DWF viewer.<<
This is a trick I learned a long time ago that I still use. Originally it would *dramatically* reduce the filesize of the resulting PDF. It doesn't have much of an effect that way anymore, but there are often noticable quality improvements still. Excellent reminder tip.
Dave.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your input.
I am just now experimenting using your advise. I like that the DWF files retains a lot of the image quality while keeping the file size small. But unfortunately clients are familiar with PDF and request them in that format.
But I will definitely use this advise.
Thank you again!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I hope you didn't forget the second step - print to PDF from dwf file using autodesk design review ? ![]()
