• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010
    Member
    bhandy1986
    Layer Manager Xref Madness
    255 Views, 4 Replies
    02-09-2012 03:31 PM
    Like many architecture firms, we use a single xref file with all of our layers overlapping.  Then we create layer manager states to toggle between floor plans, reflected ceiling plans, etc.  When you xref this file into another, the layer states come with it.  The problem arises if you ever need to change those layer states in the original file.  The xref'd lman states that came in when you inserted the xref originally do not update, but rather remain whatever they were when you intially brought in the xref.
    The only way to fix this I've found is to delete the xref, purge and toggle visretain on and off a few times untill the xref states disapear from the lman dialog box.  then once you re-import the xref the up to date lman states come with it.
    there has GOT to be a better way to do this.  when there are several host files sharing the same xref, you can't go doing this in every file just to update the lman states.  Exporting the layer states does not work because the xref and the host file don't share layer names (because autocad adds a prefix to all layer names)
    ****Sage
    Re: Layer Manager Xref Madness
    02-10-2012 07:46 AM in reply to: bhandy1986
    Is something is in your top file, bringing in that exact same item from outside will not change it: this applies to text styles, dimstyles, block definitions, layer settings and so much more.
    Is that a good description of your issue? Yes, you either have to remove the "thing" from your top file or rename it in order for it to get replaced with the new "thing" you are bringing in.
    Please mark any response as "Accept as Solution" if it answers your question.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    RSS: http://ltisacad.blogspot.com/feeds/posts/default
    Twitter: http://twitter.com/LTisACAD
    Pinterest: http://pinterest.com/pendeaninc/pins/
    Member
    bhandy1986
    02-10-2012 09:42 AM in reply to: pendean
    Once the layer state from the xref comes into the host file (which happens once, when you first insert the xref) that layer state won't update, even if you update it in the xref and save.  is there a way to tell autocad "reload the layer states from the xref"?
    If not, is there maybe a macro or lisp script that can do all that?
    In order to reload the updated layer states you have to delete them first so they can be brought back in.
    I've noticed getting rid of the xref'd layer states is tough.  The only way I've found is to delete the xref, purge and reinsert the xref.  anyone have any ideas?  because I have to do this all the time, I'm looking for an efficient work around.
    thanks
    Member
    bhandy1986
    02-10-2012 10:20 AM in reply to: bhandy1986
    I found the solution in another forum, in case anyone else had this problem
    ^C^CQSAVE;VISRETAIN;0;XREF;R;*;VISRETAIN;1;^C^C-XREF;R;*;
    I used this macro and it worked. the next time you restore a xref'd layer state, it will reflect whatever changes you made to the layer state in the xref.
    ****Sage
    02-10-2012 01:25 PM in reply to: bhandy1986
    Basically your original fix in a macro.
    Dean Saadallah
