• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010
    Valued Contributor
    Dimension that Spans 2 drawings
    135 Views, 1 Replies
    02-07-2012 07:56 AM
    A little help please;
    I'm trying to get everyone on the right page, but I can't find any reference to how to properly show a dimnesion that spans across 2 different drawings (with use of a matchline or on a piping isometric that is split). Would either of these examples be the correct way to show a dimension that spans 2 drawing files? Is there a different way to show a dimension that is to span 2 drawings?
    Thanks for your help on this.
    **Master
    Patchy
    Re: Dimension that Spans 2 drawings
    02-07-2012 08:31 AM in reply to: tstorzuk
    I use the upper one for spanning to next sheet.
    The lower one you see more often when a same shape (like piping or steel beam shows broken) but there should be an extension line on the right side.
    These were taught to me when I learned Technical Drafting many years ago, anyone else can do differently, but in the end I can figure out what they want to show.
