• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010
    Member
    Bring Description Keys into Civil 3D 2012
    162 Views, 3 Replies
    02-01-2012 11:44 AM
    I am tired of re-creating Description Keys everytime I want to bring in Survey Points into a drawing.  I have tried to drag and drop, but that does not seem to work for me.  I can's copy it.  Is there a way to get Civil 3D 2010 Decription Keys  into Civil 3D 2012.  Any advice.
    Utana
    Product Support
    machadt
    Re: Bring Description Keys into Civil 3D 2012
    02-02-2012 05:50 PM in reply to: utanadye
    Hi Utana,
    Sure it is way, just open one of your drawings that has your DescKey Set on it in Civil 3D 2010, make sure that you delete all the information on it and PURGE the drawing, do a save as just in case, so you don’t damage or over right something.
    Now open your Civil 3D 2012 and insert the drawing that you just created and clean in 2010 using the INSERT command.
    This will bring any styles and also the Description Key set to your drawing in 2012 that you can save as a template or work on it.
    Please take a look to this short video that illustrates what I am saying.
    http://screencast.com/t/YDRPcwrmTF7f
    Hope this will help.
    Tatiana Machado
    Americas AEC Infrastructure Product Support Specialist
    Member
    02-03-2012 10:23 AM in reply to: machadt
    It worked like a gem.  Thanks.
    Product Support
    machadt
    02-03-2012 11:11 AM in reply to: utanadye
    It is my pleasure to help!
    Tatiana Machado
