AutoCAD 2010/2011/2012
Message 1 of 5 (270 Views)
xref Manager Issue
270 Views, 4 Replies
06-24-2012 05:08 AM
Dear All,
I xref a file a file with "Irrigation Rev28" with relative path methode. When I change the revision I remap the file to new revision. But in the xref manager file name show the old one, and saved and found path locations it shows the actual one. Is there any way to change in xref name also.
Regards
Shammy.
Distinguished Mentor
Moshe-A
Message 2 of 5 (254 Views)
Re: xref Manager Issue
06-24-2012 11:04 AM in reply to: shameem4u
Shammy,
attachment of xref is special case of block insert/reference and the block name basicly can reference any dwg file.
at first the block reference gets the name of it's dwg reference but if you remap it won't change automaticlly.
to fix it, you need to rename it or detach and attach it again.
Moshe
Message 3 of 5 (238 Views)
06-24-2012 09:39 PM in reply to: shameem4u
Thanks for  your replay.
If I re attach I will lose all my layer setting in layouts.
Regards
Shammy
Active Member
Message 4 of 5 (211 Views)
06-25-2012 09:48 AM in reply to: shameem4u
yes you can, under Details change it on Reference Name.
Moshe-A
Message 5 of 5 (201 Views)
06-25-2012 09:45 PM in reply to: shameem4u
yes, but you can 'capture' current layer properties with layer state manager (LAYERSTATE command)
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
