My windows do not display in any layout tab. The doors display as well as all other objects. The A-Glaz layers is turned on and all other choices in the layer window are on. Although I fixed this issue by exploding each of my windows in the layout, I do not understand why this happen and why I could fix it by exploding each window?
Are you speaking about AutoCAD Architecture (as you are writing about windows and doors)? If so, there is a separate forum for >>>AutoCAD Architecture<<<
If your windows and doors are block-objects then you should verify the layer-settings not just for the insertion layer of the block, but also the layers of geometry contained in the block. Also necessary is to check the layer-settings while you are in that special viewport, because only then you'll see and viewport-depending layer-settings like overrides or VP-layer freeze ...
- alfred -
