AutoCAD 2010/2011/2012
New Member
AFitchguy07
Message 11 of 19 (1,816 Views)
Re: slow autocad after block editor
02-06-2011 11:53 AM in reply to: *elenist
I, too, just started having this issue yesterday. I have been using 2011 full since last summer and never had any issues until yesterday. It was driving me nuts! Zoom e does work for me to prevent the jumpy cursor.
I did notice acad.exe in task mngr does go up to about 40% of cpu ussage when i exit block editor and move the cursor around only within the application. Not sure what it is. Would love to figure out what it is since it worked fine until yesterday.
Windows 7 Ultimate x64
Acad 2011
Member
Message 12 of 19 (1,801 Views)
02-08-2011 06:28 AM in reply to: AFitchguy07
Hello!!! We need help. Where are the autodesk people. This is a huge problem since autocad 2010 was working fine and because of the obligation of licence renwal i'm stuck with a program that is faulty....
New Member
AFitchguy07
Message 13 of 19 (1,794 Views)
02-08-2011 07:22 AM in reply to: Loomsdak
Does zoom extents not work for you? I had 2011 and it worked fine until last week.
LeafRiders
Message 14 of 19 (1,738 Views)
02-16-2011 03:10 PM in reply to: AFitchguy07
I seen this happen today on another guy's machine. I had to reopen AutoCAD and it was fixed, but make sure you have nothing else open with your session of AutoCAD. Often times this can be a virtual memory thing. Autodesk will most likely pin it on this anyway so may as well close all other acad sessions and even mail etc. and then try to replicate it. If it happens then you have issues.
Ensure you have all the service packs, drivers, and hot fixes, seems to be a long list. Also, i've also found that turning my regenauto setting off helps out. I redefined my "RE" command to be regenall.
New Member
RobMorris6253
Message 15 of 19 (1,520 Views)
05-23-2011 05:18 AM in reply to: LeafRiders
Is there a resolution to this issue its a real pain inserting blocks, editing them, and then zoom extents, regen, zoom back in.
Just installed 1.1 update and no change!!!!!!!
Autocad LT 2011
New Member
dfarrellnep
Message 16 of 19 (1,226 Views)
12-14-2011 11:43 AM in reply to: RobMorris6253
Still no solution to this? Ridiculous. Very unproductive on large drawings where I have to zoom all and regen---then find where I was working...
*Pro
Message 17 of 19 (1,223 Views)
12-14-2011 11:45 AM in reply to: dfarrellnep
When I upgraded my machine from WinXp 32bit to Win7 64bit, I have yet to see that problem.
azr
New Member
Message 18 of 19 (865 Views)
10-01-2012 11:48 PM in reply to: *elenist
Try setting your Display Properties.
Right Click on Desktop select Properties / Settings / Advanced /  Trouleshoot - try dicrease your Hardware acceleratoin or Start / Control Panel / Display / / Settings / Advanced /  Trouleshoot. Hope its work
New Member
Message 19 of 19 (409 Views)
08-30-2013 12:43 AM in reply to: *elenist
Try LIMITS command.
type LIMITS on command line than select "OFF" or select first left lower corner than select right upper corner of your drawing area.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
