AutoCAD 2010/2011/2012
Fa3ien
Message 1 of 32 (2,716 Views)
"too-low-density" hatches shows up as solid !
2716 Views, 31 Replies
09-27-2011 05:27 AM
In Acad 2012 (sp1, w64), it seems that, if a hatch has a scale too
big to have something showing into the boundary, it renders as a
solid hatch ! (previously, it rendered empty, as expected).
The attached file demonstrates the issue, with "dots" hatch samples
at various scales. You can see that, at scale 80,
where no point should be visible, it becomes solid !
It's a major annoyance, since I have lots of lisp-based automatic
hatching of things, and, while it's not a problem to have an empty
hatch whenever the boundary is too small for a given scale, getting
a solid hatch instead is a big no-no.
How to get rid of this ?
Alfred.NESWADBA
Message 2 of 32 (2,701 Views)
Betreff: "too-low-density" hatches shows up as solid !
09-27-2011 06:54 AM in reply to: Fa3ien
first: I can reproduce the issue, I would see that as bug.
To now get you to a workaround I tried to reset the hatch-base-point, redefinig it/setting the point within the rectangle would solve the problem (at least for this area).
- alfred -
Alfred NESWADBA
Valued Mentor
bgingerich
Message 3 of 32 (2,699 Views)
Re: "too-low-density" hatches shows up as solid !
09-27-2011 07:01 AM in reply to: Fa3ien
Another workaround.  I found if I "inherited properties" from another of the hatches and set the scale to 80 it would work too.  Unfortunately it only works one .dwg at a time.:smileysad:
Brandon Gingerich
Product Support
Message 4 of 32 (2,681 Views)
09-28-2011 06:43 AM in reply to: Fa3ien
Just to let you know that this is not a bug, this change is as designed.
Now you can see the hatch and change it or erase it if you don't need it anymore (as it was invisible previously and increasing the file size).
If you do not like this change please send your feedback:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
__________________________________________________________________
Please click the button "Accept as Solution" if this suggestion resolves your issue.
Alfred.NESWADBA
Message 5 of 32 (2,674 Views)
09-28-2011 07:47 AM in reply to: luconceicao
What is "as designed"? The scalefactor?
In Fa3ien's drawing you see different scales assigned to the hatches and with the example scale=80 it switches to SOLID ==> is now the scale-factor the trigger for changing the visuality of the hatch?
Than I won't understand why reassigning a base-point makes it possible to have the value 80 as valid?
Sorry for having problems with the phrase "as designed" (it is told to often) ==> reducing the hatch-density to a value under a threshold does not have to result in FULL FILLED. For me that is no "solution".
And for selecting ... look to the attached drawing (2 viewports, different scales ==> the hatch is visualized differently) where you can select a hatch at least in the right viewport ... and there is _QSELECT also for selecting :smileywink:
- alfred -
Alfred NESWADBA
Product Support
Message 6 of 32 (2,672 Views)
09-28-2011 07:51 AM in reply to: Alfred.NESWADBA
Sorry I did not explain properly.
The change that is as designed is that in AutoCAD 2012, hatches that were invisible in previous versions will show as solid.
I hope this helps.
Cheers,
Luciane
Alfred.NESWADBA
Message 7 of 32 (2,669 Views)
09-28-2011 08:03 AM in reply to: luconceicao
sorry to bother you, but please solve the situation in my drawing with the "as designed solution".
The situation is:
  • I want to have a large distance between the points even if there are areas to small for the hatch.
  • I have two (or more viewports) with different scales
  • In the sample left side/left viewport I don't have to get this polyline filled.
And ... it's no choice to remove the annotation-scale from that hatch, because there could be more then one hatch and therefor there could be polylines with more area (and so the hatch visible as "light-dotted") .... and that could be hundreds of hatches ==> so manually choose annotation-scales remove/add hatch by hatch/scale by scale is also not a possible way.
- alfred -
Alfred NESWADBA
Product Support
Message 8 of 32 (2,664 Views)
09-28-2011 08:23 AM in reply to: Alfred.NESWADBA
Hi Alfred,
Thanks for your message.
I highly recommend that you send your feedback to our development team. The link to the form is:
Cheers,
Luciane
Alfred.NESWADBA
Message 9 of 32 (2,660 Views)
09-28-2011 08:31 AM in reply to: luconceicao
done.
- alfred -
Alfred NESWADBA
Product Support
Message 10 of 32 (2,656 Views)
09-28-2011 08:41 AM in reply to: Alfred.NESWADBA
Thank you.
If other users have the same issue I suggest that they also complete the form.
Cheers,
Luciane
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
