AutoCAD 2010/2011/2012
V
Active Member
Message 1 of 10 (3,978 Views)
mbuttonpan doesn't work!
3978 Views, 9 Replies
08-23-2010 12:02 PM
When I type "mbuttonpan"  so I can depress my mouse roller ball to pan, it doesn't work.
It worked on a different wireless mouse.
The one I am currently using is a wireless Logitech EX100 mouse.
V.
namssurt
Message 2 of 10 (3,975 Views)
Re: mbuttonpan doesn't work!
08-23-2010 12:22 PM in reply to: V
set the middle button in setpoint to middle button.
jg
V
Active Member
Message 3 of 10 (3,969 Views)
08-23-2010 12:37 PM in reply to: namssurt
jg,
UMM... Where is the setpoint?
V.
V
Active Member
Message 4 of 10 (3,964 Views)
08-23-2010 12:52 PM in reply to: V
Fixed it!
Thanks!
Active Member
eelkovdm
Message 5 of 10 (3,473 Views)
03-09-2011 02:11 AM in reply to: V
I have a similar problem,
I use a logitech G5 laser mouse, and have my scrolle wheel set to middle button in setpoint.
mbutton pan variable is set to 1 and still I can't pan.
it has worked on this computer but afther upgrading to AutoCAD Civil 3D 2011 is has stoped working.
OS = Windows xp 64bit
any other solutions to this problem out there?
would be mutch appreciated
*Expert Elite*
M_Hensley
Message 6 of 10 (3,467 Views)
03-09-2011 03:36 AM in reply to: eelkovdm
To get my middle button to work properly with AutoCAD I had to go into control panel > mouse > wheel > exceptions and add AutoCAD as an exception.  (Not all mouse drivers have this ability.)
Active Member
eelkovdm
Message 7 of 10 (3,462 Views)
03-09-2011 03:57 AM in reply to: M_Hensley
I'm using setpoint and have added autocad as a "game" and then again set the scroll wheel as middle button.
but no succes yet....arggggg
New Member
caspidopapidos
Message 8 of 10 (3,460 Views)
03-09-2011 03:59 AM in reply to: V
try setting a ne value, it must work interchage between <1> and <0> values
Active Member
Message 9 of 10 (2,750 Views)
04-11-2012 09:33 AM in reply to: caspidopapidos
I have 2 different PC's with Logitech mice... One wireless, one corded. I have found that the Logitech SetPoint mouse software causes a major lag with the scroll wheel pan (with the scroll wheel set to Middle button instead of the default zoom). I have uninstalled the Logitech Setpoint software and the OS (Windows7 64 in my case) defaults the mouse to HID-compliant mouse. Pan and zoom on the scroll wheel work great in AutoCAD and the forward-back buttons still work in IE.
Downside is that you will loose any additional button functionality on the mouse (Application switching, keystroke customization and other goodies)....  Not a problem for me.
New Member
Message 10 of 10 (1,941 Views)
02-09-2013 10:21 PM in reply to: namssurt
This solution previously noted to set wheel as "middle button" in Setpoint worked for me.  It was somehow set as "Mouse:zoomset".  I set this under "Select Program - AutoCAD Application".  MBUTTONPAN set to "1".
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
