AutoCAD 2010/2011/2012
Valued Contributor
rewis
Message 1 of 31 (199 Views)
jerky pickbox in only one drawing
199 Views, 30 Replies
10-16-2013 04:11 PM
I have read everything I can find in the search results and tried a lot of suggestions but my issue is a jerky pickbox in only one drawing file and it just started after working in this file for a month or so. All other files are fine. Everything I have found relates to the problem in all files and not just one. Is there anything that is in this particular file that would cause this?
It's to the point that the file is useless and over a month of work is lost. I've tried copy/paste into a new file for the lack of knowing anything else to do.
I really need to salvage this file. I make frequent copies of all files as I progress with them and unfortunately I copied this file just before the issue arose and that copy file is also contaminated. I've learned now that you can backup files too often!
Anyone have a suggestion? Please.
Russell
pendean
Message 2 of 31 (189 Views)
Re: jerky pickbox in only one drawing
10-16-2013 05:12 PM in reply to: rewis
SNAP (F9 key) got toggled on by chance?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
rewis
Message 3 of 31 (187 Views)
10-16-2013 05:18 PM in reply to: pendean
No, but it is similar to snap but far more erratic than snap and it is only in one particular file. All other files are fine.
Valued Contributor
rewis
Message 4 of 31 (180 Views)
10-16-2013 05:51 PM in reply to: rewis
Thanks Dean for the reply but don't stop now!
nestly2
Message 5 of 31 (170 Views)
10-16-2013 09:24 PM in reply to: rewis
Have you tried using WBLOCK to export the objects in the current drawing into a "clean" drawing.
Valued Contributor
rewis
Message 6 of 31 (153 Views)
10-17-2013 05:32 AM in reply to: nestly2
Yes Nestly, very many times through the night and that corrects the problem.........except when I close the drawing and reopen it the problem is back.
Thanks for the suggestion.
Russell
doni49
Message 7 of 31 (130 Views)
10-18-2013 11:54 AM in reply to: rewis
Can you post your file?
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Valued Contributor
rewis
Message 8 of 31 (120 Views)
10-18-2013 02:50 PM in reply to: doni49
Sorry for the delay in responding. Out of Pocket all day. The file is 3,500 KBs and it will not go.
Russell
Valued Contributor
rewis
Message 9 of 31 (114 Views)
Re: jerky pickax in only one drawing
10-18-2013 03:04 PM in reply to: rewis
One additional symptom. I can start a fresh file and copy/paste the problem drawing into it and all is fine...until I close the file and re-open it and then it's back to being jerky again.
Russell
doni49
Message 10 of 31 (111 Views)
Save the file to a different location. The on the copy, run purgeall command (repeat until there's nothing left to purge). Then if need be, zip the file.
The purge will make the file smaller. The zip will also be smaller yet. AND I think the site permits zip files larger than the dwg files it permits.
You should be able to post after that.
Don Ireland
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
