AutoCAD 2010/2011/2012
Active Contributor
laneclare
Message 1 of 6 (264 Views)
inserting block with attributes
264 Views, 5 Replies
04-11-2012 06:12 AM
Hello.  I have a ridiculously stupid question, and I apologize.
I have a ton of blocks with attributes.  Sometimes when I insert them, AutoCAD (2011) prompts me in the command line (perfect).  Other times, a prompt box appears to insert attribute definitions (annoying).
What setting do I have wrong, or am I setting the blocks up incorrectly?
Thank you so much for your help.
Alfred.NESWADBA
Message 2 of 6 (263 Views)
Re: inserting block with attributes
04-11-2012 06:16 AM in reply to: laneclare
the sysvar ATTDIA (>>>details<<<) defines if dialog opens or the commandline is used to get the values of the attributes.
- alfred -
Alfred NESWADBA
Active Contributor
laneclare
Message 3 of 6 (259 Views)
04-11-2012 06:28 AM in reply to: Alfred.NESWADBA
Thank you so, so much.  I've been going nuts trying to figure this out.  My problem was that I was inserting from a toolbar, so the setting (I think) was being transferred over from the source file.
Thanks so much.
Active Contributor
laneclare
Message 4 of 6 (250 Views)
04-11-2012 07:12 AM in reply to: Alfred.NESWADBA
Actually, that isn't fixing my issue.  I deleted the items from the tool pallette and reloaded them on there, but they're still inserting with the prompt from the toolbar.  From the insert command, though, it works fine, in line prompts, no box.
Ideas?
Alfred.NESWADBA
Message 5 of 6 (238 Views)
04-11-2012 07:54 AM in reply to: laneclare
OK, toolpalette is the thing to search for (including INSERT and ATTDIA) ... getting a lot of results, all similar to this thread. At least it seems to be a problem for many releases now and looking e.g. to >>>this thread<<< a LISP statement would be the only chance to get the attribute-request in commandline working.
- alfred -
Alfred NESWADBA
Active Contributor
laneclare
Message 6 of 6 (234 Views)
04-11-2012 08:06 AM in reply to: Alfred.NESWADBA
Thank you so much.  Also, thank you for telling me what you searched to get there.  I had just gotten that combo together, and was weeding through the top of the list from google.  Thanks so much.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
