AutoCAD 2010/2011/2012
New Member
JenksJT
Message 1 of 8 (18,055 Views)
Accepted Solution
how to turn off Selection dialogue box??
18055 Views, 7 Replies
07-28-2010 05:39 PM
A selection box has appeared out of no where in AutoCAD 2011. Whenever I enter a command then select an object a dialogue box called 'selection' appears with a list of possible objects for me to select.
It is extremely annoying. I have attempted to turn it off in options> setting but nothing seems to turn it off.
Can someone please tell me how to turn it off?
Thanks!
Jenks
Valued Mentor
wengle
Message 2 of 8 (18,042 Views)
Re: how to turn off Selection dialogue box??
07-28-2010 08:13 PM in reply to: JenksJT
I wonder if you mean Quick Properties. If so, type qpmode and set to 0 (zero) - I use setting of 2.
New Member
JenksJT
Message 3 of 8 (18,032 Views)
07-28-2010 10:59 PM in reply to: JenksJT
I just found it,
it is SELECTION CYCLING
If this ever happens to anyone it is a small green box next to the quickproperties box down on the tray setting toolbar.
you can turn it on and off.
New Member
ssmith1971
Message 4 of 8 (17,567 Views)
01-31-2011 01:32 PM in reply to: JenksJT
THANK YOU SOOO MUCH!!!  I was getting ready to loose my mind until I tried the selection cycling option...it worked :smileyvery-happy:
Ron-C
Message 5 of 8 (17,561 Views)
01-31-2011 01:41 PM in reply to: JenksJT
Another thing to keep in mind...........if your autocad slows down and the cursor is jumping all over..........you'll need to turn Selection Cycling OFF ...........it drives me nuts...........
Hope they fixed this in 2012 !!!!!!!!!
Ron
Distinguished Contributor
msorensen
Message 6 of 8 (13,650 Views)
07-10-2012 11:02 AM in reply to: JenksJT
Thank you!  Thank you!  Thank you!  I managed to get this done once, then promptly forgot how and it re-set to pop up again.
Melody
*Expert Elite*
heinsite
Message 7 of 8 (13,622 Views)
07-11-2012 02:36 PM in reply to: JenksJT
I don't know why, but for some reason this question dragged out an old insurance claim quote I read once:
"As I approached the intersection, a stop sign suddenly appeared in a place where no stop sign had ever appeared before. I was unable to stop in time to avoid the accident."
:smileytongue:
Dave.
Dave Hein, P.E.
Member
Architektus
Message 8 of 8 (3,094 Views)
04-02-2014 07:27 AM in reply to: JenksJT
And, that small green box next to the Quick Properties, needs to be turned on / made visible on the taskbar/tray by right-clicking on the tray, selecting the Status Toggles fly-out menu, and THEN ensuring that Selection Cycling is checked / selected.
Apparently, Ctrl-W does this as well, which is probably how I got myself into this predicament in the first place. Nothing like a simple key command to ruin the last two days of your life. **** popups - grrr autodesk.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
