AutoCAD Forum
how to save settings in cad 2011 prior to re-install
3 REPLIES 3
steve
413 Views, 3 Replies
Hello, running a small office here, and would really appreciate some assistance in the re-install process.
What is the best way to save or export all settings that were configured prior to a re-install so that the new install will work with the same as before.
Settings like cursor size, dynamic snap settings, printers, path locations, layout apperance, etc. We have both a autocad 2011 and autocad 2010 lt license. Is there a solution for both?
Thanks in advance for any help!
3 REPLIES 3
Patchy
in reply to: steve
Most settings is in your autocad SUPPORT Folder, save it in a flash drive and later overwrite your newly installed.
Also need to go to OPTIONS, Profiles tab, highlight your profile and export your settings; save it to your flash drive and that is about all.
steve
in reply to: Patchy
Thanks for your help, will give it a shot and let you know how it goes.
Do i need to create a profile of current settings before exporting or does acad do this automatically?
steve
in reply to: Patchy
It worked perfect, thanks for your help!!
”Boost
