AutoCAD 2010/2011/2012
Distinguished Contributor
barry2104
Message 1 of 8 (4,786 Views)
how to delete a hole in my hatch
4786 Views, 7 Replies
01-16-2012 08:33 AM
i opened up a drawing which had a hatch over an area, and after deleting some text from within the hatch extents, found that the hatch didn't ignore the text & put the hatch behind it, rather, it created an island around the text to avoid a hatch/text clash.
I've removed a few pieces of such texts, and now have a bunch of rectangular holes in my hatch where the texts used to be.
How can I remove these islands completely without having to rehatch the whole thing again?
(I realise I could simply minimise the size of the island by picking the four corners/vertices of the hatch and bringing them closer together, but this is a messy solution)
Thanks in advance
Patchy
Message 2 of 8 (4,783 Views)
Re: how to delete a hole in my hatch
01-16-2012 08:40 AM in reply to: barry2104
Try this, type in WIPEOUT,  F for frame, then ON
If they show up, delete them or you can use QSELECT, and remove them in one swoop.
barry2104
Message 3 of 8 (4,777 Views)
01-16-2012 08:52 AM in reply to: Patchy
nope, nothing to do with wipeouts/Tframes.
it's a simple hatch island, and can be created around text or other closed elements (e.g. a circle within a hatch boundary will also reveal such an island).
all i want to do is delete the islands. I can remove one of the vertices of the rectangular islands, but the islands can't be reduced to less than 3 points using this method.
Patchy
Message 4 of 8 (4,775 Views)
01-16-2012 08:56 AM in reply to: barry2104
Attach an example, let's see why
barry2104
Message 5 of 8 (4,772 Views)
01-16-2012 09:00 AM in reply to: Patchy
attached...
Patchy
Message 6 of 8 (4,764 Views)
01-16-2012 09:17 AM in reply to: barry2104
Hatchedit, remove boundaries will work on the rectangles.
The 3 circles are not boundaries, it's a continous line from the perimeter that is why you can't delete it.
Message 7 of 8 (4,736 Views)
01-16-2012 05:45 PM in reply to: barry2104
You could highlight the mid point grip of each arc, right click, and choose Convert To Line.  That will get rid of the circular holes.
barry2104
Message 8 of 8 (4,724 Views)
01-16-2012 11:01 PM in reply to: Patchy
to be clear for anyone looking for the process to resolve this problem without having to go through hatcheditor:
1) select the hatch (you will see the "Hatch Editor toolbar come up at the top of your page)
2) click on the Remove icon (LHS)
3) click on a boundary of an island you want to delete & it will be removed instantly!
thanks
this would have been the slower solution going through hatcheditor COMMAND, fyi:
HATCHEDIT
> click "Remove boundaries" icon
> select an edge of one/all of the islands you wish to delete (the entire hatch will look to be selected once you do this) then press enter/confirm
> back in the Hatchedit window, you then need to click the "Display boundary objects" icon, which as far as i can tell, sort of regenerates the hatch. (if you simply click ok/close the hatchedit dialogue without clicking the "Display boundary objects" icon, then it won't work)
> then you can click OK and you're good to go
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
