AutoCAD 2010/2011/2012
New Member
Message 11 of 18 (835 Views)
Re: hatch turns solid when dwg opened in Autocad 2012
01-10-2012 02:14 PM in reply to: AolahSDA
This is not solved....... i have attempted all these solutions and it still does not rectify.
Distinguished Contributor
d_reno
Message 12 of 18 (817 Views)
01-16-2012 06:33 AM in reply to: AolahSDA
Setting HPMAXLINES to 10,000,000 and then loading the dwg worked for me, too.
Unfortunately, Autodesk had previously advised me to set HPMAXLINES to an relatively low number - 500 - because I was locking up the software when I grabbed a hatch object.
Not sure what the ultimate solution is.
dr
David Renaud, RLS
C3D 2012 on 64bit Win 7 all up to date
Dell Precision 7core 8GB RAM
NVIDIA Quadro FX 1800M
LDT/C3D user since release 12
Member
Message 13 of 18 (700 Views)
07-19-2012 08:22 AM in reply to: AolahSDA
Our AutoCAD 2012 users are also having this same problem.  It occurs when opening older drawings and when creating drawings.
We run a lisp routine to automate the hatching of stratigraphic logs.  Since we use the solid pattern for coal, the solid hatch replacement is creating a big problem..
In the previous versions of AutoCAD (before 2012), if an area was to small for the hatch pattern scale, it appeared as if AutoCAD would skip it and display 'boundary to small to hatch'.  Now it seems that AutoCAD will hatch regardless of the boundary area, but it will display a solid hatch although the correct hatch is assigned to that boundary.
I have tried everyone's suggestions and I still cannot get past the hatch turning solid.  The only solution I did find is to change the hatch scale; however, I also discovered that the size of the boundary is dictating the scale of the hatch to get it to display properly.
Since we generate many strip logs with many boundaries in varying sizes, to hatch edit every wrong solid hatch pattern really defeats efficiency in our processing of the work.
Please - try my theory and let me know if you agree.  And Please - anyone - let me know if this issue gets resolved or if anyone has found a work around.
cwo
oceanside
Message 14 of 18 (566 Views)
12-28-2012 05:03 AM in reply to: jonathanh
I know this was posted a year ago but we are experiencing the same problem with the hatch turning solid.  Has a solution been found for this?
the best is at the beach!
New Member
Message 15 of 18 (527 Views)
01-09-2013 06:04 PM in reply to: architects
architects wrote:
This just started showing up today. I've tried everything and the HPMAXLINES is set 1000000.
Set the varible to 10 000 000
1 000 000 is too low
Member
Message 16 of 18 (503 Views)
01-15-2013 06:07 PM in reply to: oceanside
Solution is to upgrade to AutoCAD 2013. The hatch change, per the information I found, was a planned design change within AutoCAD 2012. In AutoCAD 2013 you now have the option to go with the new hatching, or revert to legacy hatching. Once you have upgraded to 2013, set the system variable HPMAXAREAS to zero and hatching will revert to legacy hatching. Cynthia Owens DIRECTOR OF COMPUTER SERVICES CARDNO MM&A Phone +1 276 322 5467 Fax +1 304 809 0601 Direct +1 304 809 0642 Address 534 Industrial Park Road, Bluefield, VA 24605, United States Email Cynthia.Owens@cardno.com Web www.cardno.com - www.cardnomma.com
cwo
Member
Message 17 of 18 (504 Views)
01-15-2013 06:07 PM in reply to: robert.condon
Per my research, the hatching issue was a planned design change in AutoCAD 2012. The problem was corrected in AutoCAD 2013, giving the user the option to use the new hatching or revert it back to legacy. In AutoCAD 2013, setting the system variable HPMAXAREAS to zero will return hatching to legacy. Hope this helps. Cynthia Owens DIRECTOR OF COMPUTER SERVICES CARDNO MM&A Phone +1 276 322 5467 Fax +1 304 809 0601 Direct +1 304 809 0642 Address 534 Industrial Park Road, Bluefield, VA 24605, United States Email Cynthia.Owens@cardno.com Web www.cardno.com - www.cardnomma.com
cwo
oceanside
Message 18 of 18 (501 Views)
01-16-2013 04:37 AM in reply to: jonathanh
Thanks!! I'll do this...
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
