AutoCAD Forum
fatal error unhandled c0000417h exception at 7056795ah
7 REPLIES 7
Message 1 of 8
6643 Views, 7 Replies
Hi ,
I'm Facing this FATAL ERROR for almost 5 months , I had tried to reinstall my Software , repair it , sent a million error report , But sadly the problem continue to appear !!
Knowing that my PC is new and I don't use it at any anthor activity but AutoCad !!
So please help me to find a solution for this .
Thank you .
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
welcome @forums.autodesk.com !
When do you get this error ... and how often?
What are your system specs (OS, graphic card, driver, service packs, ...)?
And most important: cam you reproduce the problem? If so what are the exact steps?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
in reply to: Alfred.NESWADBA
first of all thanks for your interest ..
This error is just showing up while working .. no certine action is taken by me before that !!
and asking how often it always appear , every time I use my autocad !!
my OS : Windows 7 Ultimate 32 Bit , Graphic crad is RADEON .
and the most important I can't reproduce the problem , I just open the program and the error appeas after while !
Message 4 of 8
Alfred.NESWADBA
That might be once a day or every 10 minutes ...
Which one exactly? Can you verify if it's a tested card and if so, do you have the driver installed that is certified for AutoCAD? Check all that >>>here<<<
Most importand (sorry that I forgot it in my first reply): check that you have installed the current service pack for your AutoCAD release >>>here<<<
Then verify your drawings you work with, e.g. run _AUDIT to check the integrity of the DWG internal database.
Try to do your work with new drawings, maybe with a new Windows user account.
Good luck, - alfred -
Alfred NESWADBA
Message 5 of 8
let's say it's every 10 minutes .. meaning that every single time I lunch the program !!
>>I can't find my Radeon in the list you gave me ! It;s RADEON 74050M
This one I can't Understand !!
and I'm going to check the last ServicePack now .
Thanks again !
Message 6 of 8
Alfred.NESWADBA
So it's during startup or you can start AutoCAD fully and work some minutes before it crashes? (Just want to make sure about that).
>> It;s RADEON 74050M
I guess you mean 7450M? Then I'm missing your AutoCAD release now to do my searches.
>> [...] _AUDIT [...] This one I can't Understand !!
Start AutoCAD, open your drawing, then type in the command _AUDIT (>>>details<<<), that will start a check with your drawing and reports problems if there are one.
..and if that does not help (and all the steps above) then create the new Windows user account and run AutoCAD with that account.
- alfred -
Alfred NESWADBA
Message 7 of 8
Firstly I'm sorry Ihad to go for a while !!
Yes that's completely true .
>> _AUDIT
I tried it but found no error !
I had downloaded the Update 2 !
Message 8 of 8
pendean
You are in a laptop? Which one?
1. Turn off Win7s aero theme
2. Change AutoCAD's hardware acceptation setting (if it's on, turn it off, if it's off then turn it on).
3. When you installed AutoCAD did you make sure the antivirus was turned off?
”Boost
