I normally do my traditional drawing with orhtographic views. in conjunction with this, I use flatshot to create the required drawings. but then when I export my drawing. I encoutered this annoying problem. my dimensions aare there but my flatshot drawing is not visible. please help. need to end this problem once and for all. I'm new to this export thing. so I dont have much exposure on this field.
Solved by steve216586. Go to Solution.
It sounds like your flatshot block is in one plane and your dimensions are in another. While using flatshot you should bring the separate views into the same plane view, then you can dimension as normal all in one view.
I also think Export command uses the default view (top). Where if you plot to .pdf you can assign different views (front, side etc) through the use of viewports.
Could the layer the model is on be turned off in the viewport?
here. I attached a file for further clarification. by the way, the file inserted has the opposite problem. i dont know if this is a bug or not.
Thanks for attaching the drawing. It is much easier to diagnose a problem.
The layer ADDITIONAL is set to "no plot" in the layer manager. If you click the icon to plot in the layer manager, it will export fine.
