AutoCAD Forum
empty drawing, purged all
4 REPLIES 4
wang890
552 Views, 4 Replies
used -purge and purged all the regapp this and that. still 3.42mb.
started with 400k from new blank template metric without template, then i pasted in this boundary polyline and some mtext and leaders. then it screws up this file. see you experts have any magic.
i tried google and played with many different ways. those objects are the culprit. if you block it out it will make the blocked out file large. just a simple polyline boundary. 100 vertices at most with some coordinates labeled. but i should mention the file was exported from civil 3d first and those exploded exported objects are the ones being copied.
empty big file is attached.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
4 REPLIES 4
rkmcswain
in reply to: wang890
Just as I suspected Smiley Wink
It's full of the DGN linetype bloat.
Here is what I get when I run DGNPURGE (more info on that here)
"DGNPURGE"
Purged 1652 unreferenced complex linetype records (of 1652).
Purged 27178 unreferenced strokes (of 27178).
R.K. McSwain     | CADpanacea | on twitter
wang890
in reply to: rkmcswain
thank you very much, this is probably why. i see a million weird linetype loaded in current drawing.
i guess i never seen this before because i never had to deal with ustn stuff. i can do .net programming been doing that for many years but don't really feel like it right now. can't take credit on this one anyways. i will get those c# code compiled later.
but easier, maybe you have the dll i can netload that works for 2012 versions?
Stantec
wang890
nevermind, i didn't read carefully just go straight to that Kean guy's code. looks like there is one hotfix for 2012.
here's a paste for other people:
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-C2-AE-dgn-hot...
testing it now. will report back in a few minutes.
Stantec
wang890
yep that fixed it. you are the man.
Stantec
”Boost
