AutoCAD 2010/2011/2012
Member
Message 1 of 4 (1,239 Views)
draw arc tangent to a circle and a point
1239 Views, 3 Replies
10-24-2012 12:31 PM
Hello House,
I am new here but I need help on how to draw an arc tangent to a circle and a point.
The attachement here is a detail of the problem I'm having. No 9
Please profer solution.
Thank you
Valued Mentor
Message 2 of 4 (1,226 Views)
Re: draw arc tangent to a circle and a point
10-24-2012 01:24 PM in reply to: waridel
Draw offsets from your items, draw a circle the same radius as your offset distance at the point where line cross, and then trim where you need too.
Regards Steven Gray
Setting Out (Joinery Manufacturing)
Autocad 2013LT
Windows 7 professional
Member
Message 3 of 4 (1,197 Views)
10-24-2012 10:29 PM in reply to: steven-g
please attemt the head of the spanner not the handle
Thanks alot
Valued Mentor
Message 4 of 4 (1,171 Views)
10-25-2012 11:53 AM in reply to: waridel
You can draw the circle with a radius of 53 and the two lines that form the mouth of the spanner, all that information is given on the sketch. The curve you want I think is 30 but it is difficult to make out on the image, but using 30 all you need do is offset from the head of the spanner by 30, your new curve centre has to be somewhere on that offset  line. You cant offset from a point but you can draw a circle of 30 centred on that point, where these two lines cross is the centre you want.
Regards Steven Gray
Autocad 2013LT
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
