AutoCAD 2010/2011/2012
Active Member
mas352
Message 1 of 4 (104 Views)
defining what it means to select "last"
104 Views, 3 Replies
05-09-2012 12:15 PM
So I have this script I used to run in AutoCAD 2011 which involved mirroring a group of many layers and then moving the "last" object created. In 2011, when I moved "last", it considered everything I mirrored to be "last." In 2012, it is taking strinctly the last object I created, not the group of layers that I mirrored, to be "last." Is there an internal variable I can change so that "last" can mean everything I just mirrored again?
May
*Expert Elite*
Patchy
Message 2 of 4 (100 Views)
Re: defining what it means to select "last"
05-09-2012 12:32 PM in reply to: mas352
You said "group", is it actually a GROUP made by group command?
Check your PICKSTYLE between two versions.
Active Member
mas352
Message 3 of 4 (90 Views)
05-09-2012 01:07 PM in reply to: Patchy
Hi, thanks for the reply.
I did create a group using the group command. I am mirroring this group of layers and not erasing the original, because i want to select everything that has just been mirrored.
In any case, I think I'm going to change my script to just select the mirrored components using a window, although this is inconvenient -_-
Thanks =)
*Expert Elite*
Patchy
Message 4 of 4 (88 Views)
05-09-2012 01:19 PM in reply to: mas352
Pickstyle variable controls the last 1 entity or the last group.
same thing as if you use CTRL+SHIFT+A
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
