AutoCAD 2010/2011/2012
Distinguished Contributor
zippy216
Message 1 of 5 (203 Views)
custom arrowheads
203 Views, 4 Replies
08-22-2011 12:16 PM
I know that I can create a custom arrowhead in one file and use it in that file but is there a way to create a custom arrowhead and have it display as a choice in the Qleader>Settings>Arrows pull down as well as the Properties>Lines & Arrows> Arrows pulldown?  Where are the standard arrows stored?
pendean
Message 2 of 5 (199 Views)
Re: custom arrowheads
08-22-2011 12:21 PM in reply to: zippy216
You have to ensure the block in INSERTed in your file, then it appears: there is no method for you to alter the default core offerings.
Try adding this as a startup routine in your ACADDOC.LSP file, or a macro at the start of buttons you may push on screen if you don't type, and ensure this block is already in your template files.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
GrantsPirate
Message 3 of 5 (193 Views)
08-22-2011 12:28 PM in reply to: zippy216
Have the arrow head as its own drawing and place that drawing in a folder on the search path for AutoCAD.
zippy216
Message 4 of 5 (191 Views)
08-22-2011 12:29 PM in reply to: GrantsPirate
where are the stock arrowheads stored?
pendean
Message 5 of 5 (187 Views)
08-22-2011 12:35 PM in reply to: zippy216
Nowhere you can access or edit or change or remove. Create a DIMSTYLE with your arrowhead in a template file, drag and drop it from a TP or ADCenter from your template file is another option.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
