Having no success in getting my .ctb file from 2007 to show in list in 2011. Is it compatible or will I have to re-write?
Russell
Could the problem be simpler?
- Your file is set to be STB and not CTB and you need to use CONVERTPSTYLES command to flip it.
OR
- You put your CTB in the wrong folder: while in AutoCAD start STYLESMANAGER command and AutoCAD will open the correct folder for you.
Not only did I go from 2007 to 2011 AutoCAD I also went from Windows XP to Windows 7. I did a search and put the .ctb file where the results found the other files. Windows 7 search engine sucks. I was not knowledgeable about STYLEMANAGER. Any way that worked for me.
Thanks very much for your help.
Russell Rewis
