I received several drawongs from a customer and on 1 of the drawings when I select any draw command, line, circle, dimension, etc. the cross hairs lock on 0,0 and will not move. I can modify existing objects but can not draw any new objects. This only applies to model space everything works fine in paperspace. Any ideas?
May be as simple as turning SNAP off or adjusting the setting to a lower value.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Thanks! I feel so stupid. I have not used Autcad much in the last 10 years, I have been doing primaraly 3D modeiling.
Don't feel bad, that has tripped up more than a few users over the years. It used to be one of the less evil tricks people played on each other.
GrantsPirate
