I can't copy objects fron autocad 2012 to autocad land desktop 2009.
When i choose paste , it pastes the objects as print screen, objects into the screen. As youcan see to photo.
From 2009 to 2012 there is no problem.
Please help me.
welcome @forums.autodesk.com!
WBLOCK can directly save to DWG2007-format 😉
So no need to reopen the wblocked file and save it back.
- alfred -
Thank you all for your time.
It happens and with a simple polyline not only with wblock.
What can i do?
WBLOCK is not an object, it's a command that saves some objects from your current DWG file into a new DWG file.
Start command _WBLOCK (in AutoCAD 2012) select the objects you want to get into an older AutoCAD version and save that file (in DWG2007-format).
Then start your old AutoCAD release, open this drawing to continue your work ... or insert this drawing into another DWG.
- alfred -
