AutoCAD Forum
change the parameter of the circle diameter in a ARRARPOLAR?
2 REPLIES 2
swaywood
1503 Views, 2 Replies
2 REPLIES 2
GrantsPirate
in reply to: swaywood
You can edit the source circle of the array, add a parameter and adjust it while editing the source, save the array edit and the changes are kept.
If you use the Ribbon, pick on the array, pick the Edit Source button, proceed from there.
I am in 2014, hopefully it works the same in your release.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
swaywood
in reply to: GrantsPirate
thks for your reply, i just want to change the circle diameter by the PARAMETERS IN A DYNAMIC BLOCK.
ps:the ARRARPOLAR is in the dynamic block too.
”Boost
