AutoCAD 2010/2011/2012
Member
chowluca
Message 1 of 3 (591 Views)
Accepted Solution
block attributes
591 Views, 2 Replies
02-08-2013 02:05 AM
Good morning
I am trying to create a block with 1 attribute (ELEVATION) showing a finished floor level and another text (field) to show another level derived by the sum of the attribute value + and additional (fixed) number, say 100.
I have tried using fields inside an ATTRIBUTE or a simple DTEXT but the field does not update, it only picks up the DEFAULT of the attribute, not the user entered input.
How can I do this?
attached is the block
THANKS
best regards
Luca Mangione
*Expert Elite*
3wood
Message 2 of 3 (583 Views)
Re: block attributes
02-08-2013 03:54 AM in reply to: chowluca
Instead of a text with field, you need define an attribute for the second figure.
After inserting the block, modify value of the second attribute with a field.
Please try attached block.
Member
chowluca
Message 3 of 3 (575 Views)
02-08-2013 04:18 AM in reply to: 3wood
THANKS VERY MUCH!
this really works
question: how did you get the block names inside the field list? I never could achieve that...
can you explain it in steps? I might need to create more in the future
I'd really appreciate - thanks
Luca Mangione
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
