AutoCAD 2010/2011/2012
New Member
rajzos
Message 1 of 2 (4,941 Views)
autocad to rhino (or at least 3d)
4941 Views, 1 Replies
01-23-2011 12:11 PM
hi there
we use both autocad and rhino (v4 / sr8 with vray)
we have just upgraded to autocad architecture 2011 and i cant find a way to import autocad 3d model into rhino . the dwg imports results an empty document, there is no more 3ds out from acad, there is no fbx import to rhino ... can someone please help me ?
thank you very much
rajzos
*Expert Elite*
Message 2 of 2 (4,919 Views)
Re: autocad to rhino (or at least 3d)
01-23-2011 04:50 PM in reply to: rajzos
Try exporting as ACIS (*.sat). (I don't think the ACISOUT command will work on ACA objects - you have to go through the menu or explode once and then ACISOUT).
In your thread title you state AutoCAD but in your problem description you state  ACA.  You might try over here http://forums.autodesk.com/t5/AutoCAD-Architecture/ct-p/56  where there might be someone who can better answer your question.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
