AutoCAD 2010/2011/2012
Valued Contributor
Martin60
Message 1 of 5 (385 Views)
Xreference Layers and Visretain when xref Unloaded
385 Views, 4 Replies
11-28-2012 02:25 PM
‘Drawing A’ has ‘Drawing B’ Xref’d into it.
The layers for Xref’d ‘Drawing B’ have been manipulated (colours and visibility) in ‘Drawing A’.
‘Drawing B’ is unloaded from ‘Drawing A’, and ‘Drawing A’ is then saved and exited from.
When ‘Drawing A’ is reopened, all of the manipulated layers from ‘Drawing B’ have defaulted to their ‘Drawing B’ layer state.
Note: The layer settings are retained in AutoCAD 2010 for this scenario.
Are there any other settings that may effect this?
pendean
Message 2 of 5 (351 Views)
Re: Xreference Layers and Visretain when xref Unloaded
11-30-2012 06:24 AM in reply to: Martin60
... and VISRETAIN is set to what?
May I ask the purpose of unloading the XREF?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
Martin60
Message 3 of 5 (345 Views)
11-30-2012 12:26 PM in reply to: pendean
VISRETAIN = 1
we are evolved in plant design and can have over 400 xreferences inn a CAD file.
Users like to unload xreferences at times for visual and performance gains but retain the layer settings.
when using AutoCAD 2010 this was not a problem.
Valued Contributor
Martin60
Message 4 of 5 (334 Views)
12-02-2012 05:57 PM in reply to: Martin60
This problem does not occur in AutoCAD 2013
(or AutoCAD 2010, as previously stated).
Valued Contributor
Martin60
Message 5 of 5 (308 Views)
12-16-2012 06:50 PM in reply to: Martin60
It has been determined that this problem is due to our .net code migrated from AutoCAD 2010.
The function deltes empty layers from the symbol table (i.e. purge) and in 2012 is able to do so with xref layers.
Solution was to add the following test
  If Not acSymTblRec.IsDependent Then
     	Try
      	acSymTblRec.Erase(True)
      Catch Ex As Autodesk.AutoCAD.Runtime.Exception
             MessageBox.Show("Error:" & vbLf & Ex.Message, fcn)
      End Try
   End If
Thanks to Autodesk for their assitance in resolving this.
Regards
Martin
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
