AutoCAD 2010/2011/2012
Valued Contributor
wolfgrrl
Message 1 of 3 (3,381 Views)
XREF within XREF not showing up when xrefed
3381 Views, 2 Replies
03-31-2011 06:44 AM
OK.........I have a dwg (dwg1) that I've xreferenced in a dwg (dwg2), and have subsequently xrefed dwg2 into dwg3. dwg1 is not showing up in dwg 3 when xrefed, but if I insert it as a block, it IS showing up.
  • All layers in all dwgs are on
  • Nothing is turned off
  • Visretain is set to 1
  • Dwg2, when xrefed into a brand new dwg is still not showing dwg1, so the issue is not with dwg3
I have attached dwg2, so perhaps someone could assist me in troubleshooting....I'm really frustrated and have spent a good amount of time trying to troubleshoot. Thanks in advance for your assitance!
Autocad Mechincal 2012 on Windows 7 64-bit
Valued Contributor
wolfgrrl
Message 2 of 3 (3,378 Views)
Re: XREF within XREF not showing up when xrefed
03-31-2011 06:54 AM in reply to: wolfgrrl
More info.....
I've xrefed it in trying both overlay and attach with no difference in the outcome.
Valued Contributor
wolfgrrl
Message 3 of 3 (3,375 Views)
03-31-2011 06:59 AM in reply to: wolfgrrl
I figured it out!
Dwg2 had to be xrefed in as an "attach" not an overlay. All is well now! :smileyhappy:
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
