AutoCAD 2010/2011/2012
quikdraft
Message 1 of 12 (7,727 Views)
Wipeout command Plots all black in PDF format
7727 Views, 11 Replies
03-07-2012 03:29 AM
I always try to use this wipeout command for electromechanical views that hide details so I don't have to  trim line entities. I create pdf files then plot the pdf files to a printer. Why does the printed wipeout fill in black when printing?
Thanks.
*Expert Elite*
3wood
Message 2 of 12 (7,724 Views)
Re: Wipeout command Plots all black in PDF format
03-07-2012 05:08 AM in reply to: quikdraft
Please refer to this article: "When I print the PDF file there are some "black blocks", they should be the wipeouts in AutoCAD."
Furthermore, you can try EXPLODEALL.vlx which can trim around wipeout and deleted objects under it and wipeout itself.
3wood
CAD KITS
*Expert Elite*
JGerth
Message 3 of 12 (7,716 Views)
03-07-2012 07:04 AM in reply to: quikdraft
Simplest approach, instead of using wipeouts, would be to emply a solid hatch, with the color set to Truecolor white, 255,255,255 instead of color 7.
Valued Contributor
myerpryor
Message 4 of 12 (7,648 Views)
03-28-2012 05:58 AM in reply to: quikdraft
similar to the second reply, make sure the wipeout/text mask is color 255 or 255,255,255. You can easily use qselect to fix existing drawings. The plotted pdf still plots whatever color the mask is, but it's so light you usualy can't tell.
OR use the dwg to pdf.pc3. I think it is included in the software installation, so you should have it. It doesn't matter what color the mask is.
Member
fpilson
Message 5 of 12 (7,269 Views)
08-01-2012 05:45 AM in reply to: quikdraft
The solid black hatching is a product of the driver used to create the PDF from ACAD.  Try uinsg a different driver, I was using the DWG to PDF.pc3, which produced the "black dots".  Then I switched to Adobe PDF.pc3, whcih uses a different driver, and that worked.
Active Contributor
FSJ_Mo
Message 6 of 12 (5,960 Views)
03-13-2013 03:55 PM in reply to: fpilson
We do not use wipeouts for that reason...try using mtext and background masking instead..make sure to set the background mask to use the drawing background color.
*Expert Elite*
braudpat
Message 7 of 12 (5,943 Views)
03-14-2013 01:53 AM in reply to: FSJ_Mo
Hello
You have this problem with which PDF Driver : DWG to PDF.pc3 , PDFCreator, CutePDF, etc ?
All of them ?
Bye, Pat
Bye, Pat
Valued Mentor
RockyBrown4134
Message 8 of 12 (5,907 Views)
03-15-2013 06:09 PM in reply to: fpilson
Had a similar problem with a printer with an earlier version. IT ended up replacing the device driver, if I remember correctly.
If this response answers your question, Please mark this response as "Accept as Solution"
RockyBrown
Aluminum Ladder Co.
AutoCAD 2012 / Inventor 2012
New Member
aaron.michaels
Message 9 of 12 (2,089 Views)
02-21-2014 07:19 AM in reply to: quikdraft
I've found if you change the color of the wipeout from 'By Layer' or AutoCAD's 'white' that prints as black to true color 255,255,255 (actual white, not AutoCAD white), then when you print AutoCAD figures (including from a PDF file of that figure), the black boxes, lines, etc. go away, and the figure prints correctly.
New Member
jason.c.pierce
Message 10 of 12 (576 Views)
06-24-2014 08:34 AM in reply to: 3wood
3wood's linked article is a pretty simple workaround
"Solution 1: In PDF printing dialogue, there is an "Advance" button, click it and select "print as image"."
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
